S7 1200 HSC Speed Configuration
after you change it to frequency, try compiling and saving the project, then downloading the whole project to the PLC again.
Actually how dose one download the hardware configuration. all i do is change the setting on the hardware configuration and click save. in the programming view you can click the actual download button. what is the procedure for downloading the hardware configuration?
As far as I am aware, you just have to select the PLC in the project tree, then click the download button. Someone correct me if I'm wrong.
Usually, if I make a configuration change with like the HSC instruction, I'll make the change, save the project, compile the project (I don't always do this step but it seems to prevent some problems), click the PLC, then click the download button.
Follow the prompts on the download windows, If it gives you the option to delete all or replace all, select it.
Hello
I have configured a High Speed Counter on the S71200 PLC and it is counting the frequency of pulses. The response of the counter however seems quiet slow. ie when the speed of the pulse sensor changes the counter is slow to pick up the change. I have carried out a very simple configuration no HSC Ctrl block etc used. I have hear that HSC require an interrupt? is this true and if so how is this set on the HSC on the S71200
thanks
I am having a similar problem configuring a HSC. I have followed the Siemens manual to the letter without success (I find Siemens manuals to be cryptic in the extreme). I want to calculate the frequency of pulses generated but can't figure out how the counter is supposed to be set up. Is it essential that I use a cyclic interrupt block? If anyone could post a screenshot of the configuration I would be most grateful. .
Hello, I use S7_1200. I Will measure frequency 5-100Hz. Any disadvantages or problems to consider if I use a Hardware HSC set to frequency and 1s?
1,807
Hello all, I have a strange problem with a high speed counter with a s7-1200. I have set up the hack input - it is a 2 channel a/b type which...
2,330
Hi I am designing a small system at work which will deposit liquid through a valve at a specific position. I have purchased a s7-1200 and will be...
1,910
I am working with a 1214 siemens plc and I have connected the pulse output of a flowmeter into the digital input of the cpu with the HSC enabled...
4,145
I am doing a PF correction and am using a micrologix 1200. I am trying to find the difference between 2 counts from my high speed counter. Is...
1,157
