S7 1200 HSC Store Value
Nov 2011
Ireland
182
Hello,
dose anyone know how I could store a value from a HSC for a short period of time e.g 60sec and then use this value for a calculation
Also could someone explain to me what exactly an interrupt is on a HSC?
thanks
Hello,
thanks
The HSC is counting continiusly?
Use a timer to generate a pulse every 60sec.
If pulse, move the HSC IW/ID to a MW/MD or evt. a DBx.DWy/DDy.
Not knowing the 1200, I recon the interrupt from the HSC triggers an OB. In this OB you could read the HSC contents and do an action with the least possible time delay.
Kalle
I have the general idea of what i require to do but am having trouble implimenting it.
I will require the HSC to reset to zero and have the value sent to a memory location. this will have to repeat continuously.
I am not sure about the "interrupt" what exactly it means. dose it just reset the counter to zero?
I think i will need the HSC Ctrl block but am not sure exactly
Hello, I use S7_1200. I Will measure frequency 5-100Hz. Any disadvantages or problems to consider if I use a Hardware HSC set to frequency and 1s?
1,814
Hello all, I have a strange problem with a high speed counter with a s7-1200. I have set up the hack input - it is a 2 channel a/b type which...
2,334
Hi I am designing a small system at work which will deposit liquid through a valve at a specific position. I have purchased a s7-1200 and will be...
1,915
I am working with a 1214 siemens plc and I have connected the pulse output of a flowmeter into the digital input of the cpu with the HSC enabled...
4,151
I am doing a PF correction and am using a micrologix 1200. I am trying to find the difference between 2 counts from my high speed counter. Is...
1,158
