S7-1200 Network cable supports
BryanG
Feb 2005
Manchester
1,987
I know that Siemens have their own supports for where the Network/Profitnet cable enters the S7-1200 range, but they don't support standard Ethernet cables, and they are a bit 'ouch' in price. In another thread I mentioned I had recently acquired a 3D printer, so I designed and printed my own. Pictures attached. I am a skinflint tight*rse so I used FreeCad for the design work, it can export to .dwg but I don't know the results. I have attached the FreeCad designs. I printed with a 0.4mm nozzle and 0.1mm layer height. There is space for cable ties to hold the cable even more firmly.
https://www.freecadweb.org/
  • Ethernet Cable Supports.zip
The little tabs hold, but for standard network cables there is a worrying degree of rotation available about the Z axis. I have been to a few panels where they have had duct covers off and 'played' with wiring and the network plugs were no longer at 90 degrees to the PLC. I don't have proof that this was the cause of some network problems, but fitting the Siemens version of this clip seemed to stop the issues.
The Siemens version is, I assume, made for Profinet connectors and isn't a 'good' fit with standard network connectors, plus they are expensive. These clips are a much better fit to the cable plugs, and a load cheaper, and if my supplier modifies the plug, I can modify the clip to match.
I didn't put in my original post that I print them with the back facing upwards and it is then printed as a bridge. It feels backwards but was the only way I could see to get the edges that go in to the PLC to print correctly. Otherwise I would have had to add support material, or split the print in to two and then glue them together.
Disclaimer: English isn’t my native language, so apologize for any incoming grammatical or spelling mistake. Hello everyone. I’m trying to make...
2,113
Hi All I have a baghouse control system in production for many years. But some time ago the PLC began to lose the network suddenly until I restart...
4,546
Hello guys, I got 6 PLCs with in same network for example 10.80.x.x One of these PLCs is S71200 which I'm trying to use as RTU, its IP address is...
1,145
I am networking 3 Siemens S7-1200 PLC's. what is the best way to achieve this? I want it to seamlessly pass data between the 3 units...
1,294
Hi! I'm sitting at home and experiment with two s7-1200 and want to set up communication. My laptop is on wireless and my two PLC is in the...
6,399
