TIA portal - s7-1200 - access over network
rQx
Oct 2010
Trelleborg
1,051
Hi!
I'm sitting at home and experiment with two s7-1200 and want to set up communication.
My laptop is on wireless and my two PLC is in the ports on the router.
I have set the two PLCs to IP 192.168.1.244 and 245.
And clicked in TIA portal that I use router 192.168.1.1
I can ping them and also display the integrated webserver.
I also clicked on "set PG/PC interface" and choosen:
s7-online -> wireless card -> TCP/IP.Auto
However, I can't access them from the TIA portal.
I want to load programs and Go online from my wireless laptop to my two PLCs connected to router.
Any hints?
/Tim
when I look at my IP adress on run/cmd/ipconfig it says that I have 192.168.1.77. This should be good for connecting? Or do I have to set it anyways?
Yes, I try extended download to device and then I should be able to see it yes?
that should be ok.
Yes, you'd have to click on search all accessible devices.
But I meant when you go from portal to online and diagnosis -> show accessible devices.
Anyway, both is the same
Thanks for the help!
Strange, I just started my computer from "sleep mode" and it worked. Hmmm, well dunno what happend but I'm glad it worked :)
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
794
Good, Code Totalizer: IF ( Hour = 23) and ( Minute = 59) and ( Second = 59) THEN totalizerDay_previous : = totalizerDay; totalizerDay= 0; End_IF...
1,593
I am new to Siemens world and need some help. There is existing program and I need to modify Function Block, add some inputs. I am offline. I...
2,000
Hello all, I am working on a project using an s7-1200 and tia portal v17. The project is for stepper motor control for a SMD23E2 motor. I am...
5,461
Hello all, I'm very new to PLCs, and I'm working on a system utilizing an S7-1200 PLC with a KTP400 Basic HMI, and it was programmed in Tia...
2,051
