Modifying Function Block (FB) in TIA Portal S7-1200
paulB
Apr 2003
171
I am new to Siemens world and need some help.
There is existing program and I need to modify Function Block, add some inputs. I am offline. I double-click mouse on function block in left tree. It opens. In the upper portion of the windows, where tags are defined, I see options to add Outputs and Temps, but not Input or InOut. How to add more of Input or InOut?
Thanks,
PaulB
You should be able to right click and then there should be useful options. I don't have portal open at the moment, but i think you can "insert above" or "insert below".
Ok. I see it in the menu as well.
Strange however, when I first open the block buttons on menu are "grayed-out", disabled. After I right-click they become enabled.
Thank you,
PaulB.
The menu items are context sensitive.
They become active when you select a declaration line where a new line can be appended or inserted.
You may have to expand a section that has been collapsed (the little black triangle to the left), before you can select a declaration line.
Hi All, I am working on a Triconex project (Trident controller) which has a project specific function blocks library. I need to make some changes...
1,940
26
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
691
Hey all, I have been trying to update the transfer lists on a pair of redundant CPE330s that are currently out running in the field. According...
764
Scenario: 1. An employer has a machine that isn't up to code/standards: hydrogen gas torch systems without safety shutoff valves, industrial...
54
8,933
