S7-1200 to Leibinger Jet3Up Ethernet comunication
NoName
Sep 2003
Domžale
273
[FONT=&quot]Hello all.[/FONT]
[FONT=&quot]I have a future project planned with a leibinger jet3up inkjet printer that I will have to send the print details to the printer via ethernet. I asked if a profinet verison is avaliable but it seems that it's not.[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]Has any one worked with a Siemens PLC with this type of printer and comunication? [/FONT]
[FONT=&quot]I am guessing that I will use PUT/GET functions to send control strings to the printer? [/FONT]
[FONT=&quot]Any input would be great, so that I prepaer as much as possible in advanced.[/FONT]
[FONT=&quot]Cheers[/FONT]
[FONT=&quot]Aleix[/FONT]
I would contact the manufacturer.
Based in Germany and the printer is for use in industrial applications, there is a good chance they have a sample TIA project for connecting the printer to an S7-1200 or S7-1500 PLC.
I did it recently. You need Tsend / Trcv as mentioned.
Get Scripting and Programming manual from manufacturer.
Communication is based on sending and receiving strings between You and the printer.
It's pretty straightforward.
[FONT=&quot]Hello guys.[/FONT]
[FONT=&quot]Thanks for the replies.[/FONT]
[FONT=&quot]I got the mentioned manual from the manufacturer. I will also try to get in touch for a sample TIA portal project if they have it. [/FONT]
[FONT=&quot]Will post back when I starat testing. [/FONT]
[FONT=&quot]Thanks again for the really usefull info.[/FONT]
[FONT=&quot]Great as always. [/FONT]
[FONT=&quot]Cheers [/FONT]
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
136
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
183
