horvatmiha
Hello!
I am trying to connect my PLC with SCADA. I am using S7-1200 1212C CPU (RELAY outputs). My SCADA system is iFIX 5.8 with driver S7A. I am trying to establish connection via GPRS router (TCP/IP). Port being used is 102 (default by S7A driver). In my company we have private network, SIM card in GPRS router gets static IP (set by RADIUS server) which is 10.247.XXX.XXX. My PLC has IP 192.168.0.10 set in Project. I am not sure what am I doing wrong. How to correctly set IP address in PLC to communicate in private network via GPRS router with static IP? I already enabled TCP port 102 in my router but I am not sure to which IP should I enable it because I am not sure if IP address set in PLC is correct. Should I use some communication blocks in program? I also enabled PUT/GET function (see attached pictures). Please help. Thanks in advance!
