Simple SCADA sistem (S7-1200)
NoName
Sep 2003
Domžale
273
Hello all.
I am building a machine that tests a product by extending it and retracting it. During the travel we measure force. The process is controlled by a S7-1200 PLC and we want to visualize the process with a graph of the stroke and force generated.
We want the results to be saved to a PC. So I was contemplating to use WinCC flex, but it's quite expensive.
Are there any cheaper alternatives available?
Cheers
Aleix
What you are asking for is a curve where the data is plotted freely by the X and Y axis values, aka an f(x) curve.
And you want to be able to export the corresponding force and travel values to a file.
Just so that it is clear.
WinCC Flexible cannot do f(x) curves at all, but TIA WinCC Advanced can. It costs approx 600 € for an 128 tags license.
Hello.
Yes this is the exact thing that I need. I worked with WinCC flex a few years back and I thought that with trends you can do an f(x) curve, but as you said you cant. The trend is time-based, I just checked it.
I will look into TIA advanced and other suggested software. I will post my results and experience later on.
Cheers guys, thanks for the input.
Hello.
The WinCC Advanced in TIA is pretty much a direct evolution from WinCC Flex Advanced. There will be a few differences, but it will look very familiar.
Step 7 is a huge change from Simatic Manager to TIA Portal; WinCC is almost the same.
We are looking at upgrading a very old system and I am looking for ideas on the best SCADA to try and implement. Need to be costly effective and...
3,120
I have a customer that is wanting to update their facility control system. This system is/will be controlling thing like test cell ventilation...
3,092
Hello to all, I have a rather simple application with about 12 binary inputs (BI), 4 binary outputs (BO) and 4 AI and 4 AO. I need to have a...
2,039
Hi folks, Disclaimer: I'm a PLC newbie! :D I need to create a small and cheap PLC/SCADA demo, where the underlying idea is to experience with...
2,398
I'm a newbie to the field of SCADA design and programming. Which SCADA software do you recommend me to start my training in this field with?
5,681
