Simple SCADA solution
Aden
Mar 2016
Al
Hello to all,
I have a rather simple application with about 12 binary inputs (BI), 4 binary outputs (BO) and 4 AI and 4 AO. I need to have a mini, simple SCADA application to monitor these variables. This application should have some kind of web integration, because I need this application to be opened from different computers on LAN network (just for visualization). There must be control on only one computer.
I'm considering using IGSS Free50 but it seems that this software doesn't support this functionality.
Do you have any suggestion? I need to make this with PLC, in case computer network is down, so the small drive can continue running. I'm considering either Schneider or Siemens PLCs.
Thank you.
A low cost option to consider is the AutomationDirect Click PLC with Ethernet. You can expand it to the IO you need.
For the SCADA/HMI you can use AdvancedHMI with the ModbusTCP driver. It is not web based, but you can run the application on multiple computers as long as they all have direct access to the PLC over Ethernet.
We are looking at upgrading a very old system and I am looking for ideas on the best SCADA to try and implement. Need to be costly effective and...
3,120
I have a customer that is wanting to update their facility control system. This system is/will be controlling thing like test cell ventilation...
3,093
Hello all. I am building a machine that tests a product by extending it and retracting it. During the travel we measure force. The process is...
1,614
Hi folks, Disclaimer: I'm a PLC newbie! :D I need to create a small and cheap PLC/SCADA demo, where the underlying idea is to experience with...
2,398
I'm a newbie to the field of SCADA design and programming. Which SCADA software do you recommend me to start my training in this field with?
5,681
