S7 200 and td100c alarm problem
rigicon
Aug 2009
kent
415
Greetings:oops:
I have a S7 224 and a td 100C connected programmed the user screens and 4 alarms. I generate an alarm but the screen shows no alarms .
I have done this before using a TD200 and it works so I made sure the alarm generation is correct.
On the td 200 you can scroll through the alarms to see what could be generated.
On the td100c no alarms exist to scroll yet in the data and the wizard the alarms are there.
S7 version MicroWin 4.0.7.10
Yes I know I should be using s71200 but hey these PLC's were cheap and are adequate.
Any suggestions much appreciated.o_O
o_OSomeone must have alarms working with a S7 200 and a TD100c.
Please Help - bugging me now - Here is my program the timers can be programmed etc why don't the alarms work?
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
98
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
259
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
83
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
