s7-200 (canal Plc) simulator problem...
cavusogullari
Dec 2004
21
i've been using s7_200 simulator (canal plc) for a long time. it was useful for to simulate basic functions of s7-200 plc. but recently my computer had an hardware damage and i lost my hdd. after that i setted up a new system. also i downloaded the simulator v 2.0. how ever my system is as same as the system before hardware damage, new version of simulator isn't working properly. it waits for a long time and crashes sometimes. i want to learn why this can be happen? is there anyone using this simulator and having similar problems?
note: same program is working on my notebook without any problem. (except that it is working a bit slowly)
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
93
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
80
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
