s7-200 input wiring diagram
Lil Saleh
Dec 2016
Damascus
Hello
How can I wire this sensor to S7-200 (cpu 226) ?
And what is this power supplies indicated in red arrows in the attached image ? must I install these two power supplies or these are power source?
Hello
They indicate "external" power source (PSU)
The "M" connections are where you connect your Negative/Zero Volt (0V) from an external PSU.
the Positive (+24V) from your external PSU then supplies the sensors/switches with +24V
must I connect M with 1M and 2M ?
I mean .. must I connect all the common (-) of the power supplies together?
Yes, connect the 0V (-) of the external PSU to 1M & 2M and I believe the recommendation is to also connect to M as well but I do not have the manual with me.
Hello, We have the following DI card that can accept 1,2 and 3 wire DI's ( 6DL1131-6BH00-0PH1). We plan on installing this card for use with a...
1,487
Hi every one am working on this machine ,where there is a motor that rotates an arm with high speed when the arm reaches the sensor the motor...
2,012
I have an allen Bradley micro running a fan in an industrial paint mixing facility. The input fuse is 3a. The system will run fine for a bit and...
1,992
Hi, We have a dosing system that uses the 224XP REL 02.01 CPU. It has a encoder input wired to input I0.1 and monitors the position and speed of...
2,799
I am working with a 1214 siemens plc and I have connected the pulse output of a flowmeter into the digital input of the cpu with the HSC enabled...
4,151
