adam_lhadi
Hi every one
am working on this machine ,where there is a motor that rotates an arm with high speed
when the arm reaches the sensor the motor should break with some mechanism
in the program i used the positive edge detection
the problem is that the positive edge is not always detectable
i set filter to 0.1micr also enable the pulse catch but no good results
also in the hardware circuit i controlled the mechanism coil of breaking with a slim relay
result: sometimes the arm keeps rotating and when he don't he stops but in different places
