S7-200 Programming-Timer in Subroutine, possible??
stevenPLC
Sep 2004
27
Hi all brother genius..
Anyone using Siemens S7-200 PLC? I'm using it for the first time, with CPU226, and using MicroWin4.0 for programming.
Are we able to put Timer in the Subroutine and call that Subroutine for use more than once, like what we have the Multi SFB TON in S7-Simatic?
If not Timer, is there any other way to do so to have the similar Timer function in the Subroutine?
Timers are not possible in subroutines of a S7-200 system!
That's, as mentioned by 504bloke and ilhem, not true. You can indeed use timers in subroutines. But it is impossible to use timers as parameters for subroutines, which I believe is what jacquesv was trying to say.
If you search the STEP7 MicroWIN online help you'll find in the chapter 'Subroutine' which parametertypes are allowed: BOOL, BYTE, WORD, DWORD, INT, DINT, REAL and STRING.
Using timers as parameters to subroutines is only possible in S7-300/400, which are completely different PLCs compared to S7-200.
Kind regards,
I have an issue after programming a Lenze 8200 Vector drive using Lenze Global DRive Easy software. I have connected using a Can Bus interface...
598
Hi, The MicroLogix 1200 has a Com 0 port and a "HMI/programming port". When looking at the PLC, there is a port on the left side and a port on...
1,752
Dear all How to open .b0$,b1$,b2$,da1,ix$,lx$ allen bradley plc2 files. Please help Thanks & Regards Afeef
4,410
Dear all, I have these 2 problems. 1. siemens s7 200 programming cable 6ES7 901-3CB30-0XA0 (both ends serial ports). My laptop does not have a...
3,778
Greetings, I am an Allen-Bradley programmer who has an opportunity to work with some Siemens equipment (S7-1200). The discreet stuff is pretty...
2,787
