S7-200 Set, Reset (N Bits) where N=0 ?
mhopley
Jun 2005
Manchester
65
I am looking at a S7-200 program offline that has code that uses set & reset commands but the length is set to 0.
The online helps states that you can set or reset from 1 to 255 points.
Does anyone know what the value of 0 does? I presume nothing but I want to make sure it is not some sort of undocumented trick.
TIA
TIA
This feature is not undocumented. The parameter is used to specify if there are more signals to reset.
Example: R m 30.0,2 wil reset M30.0, m30.1 and M30.2.
I hope it helps.
I hope it helps.
The way I have used this in the past is with value of 1 to set/reset 1 bit. So R M 30.0,8 resets the whole byte.
Unfortunately I do not have a PLC here to test with. Can someone confirm this is right or wrong?
Yes, you are right. With 0 you set or reset no bit. With 8 you set or reset 8 bits. After reading again your question I came to understand what you were really asking and I don't know.
Sorry
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
510
I'm having issues trying to Factory Reset my S7-1200 CPU. I purchased this controller used, so it came with an IP address already assigned and a...
6,356
Hi Guys I have an s7-1200 just got it used...I am trying to connect to it directly with my pc. All the LED's are flashing. I am using STEP7 5.5 to...
19
10,247
I have an application where we're using a Micrologix 1200, and there's a timer on that we use in our program where the preset value resets itself...
1,859
hello i want to know that how i reset a counter value automatically on a specific time(e.g at 2 am)or after month or one year in siemiens s7 200
2,096
