S7 200 tip41 and Modbus RTU master/slave
Apel
Aug 2007
Singapore
98
HI,
Whole day I was just doing trial and error with S7 224xp and SquareD PM710 , wanted to read data from Pm710 module to PLC,I first tried but fail.1st i used the library modbus instruction but it does not communicate..giving error=3,means no response from slave, then i tried to used tip41 from siemens , but i dont know why this is also not working. i check every parameters required, I set baud=9600, parity=none,data bits=8, stopbit=1,address=1
using port-0 of the cpu.any one can help,
NOTE:in the PM 710 manual , register address starts at 4000.
please any one have clue?
I have attched both the program.
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
93
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
80
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
