s7 300 a basic question
yantrak
Mar 2010
new delhi
30
hi all,
the program segment in stl is as follows
network1:
1. a m 0.0
2. jc l1
3. a m0.1
4. jc l2
m0.0 =0
m0.1 =1
i don't know:
1.the value of rlo before step 1
2.the vaue of rlo after each step
hlp aprctd
thnx
thnx turpourpo
m0.0 = 0
m0.1 = 1
these values exist before the start of network 1
i'm confused beacause i think that after executing step 1 the RLO becomes 0.
so at step 3 and thereafter RLO remains at 0 until some set or or instruction.
but i know that this is wrong but where?
thnx agn
hi ld,
as mentioned m0.1 is 1
"A checks whether the state of the addressed bit is "1", and ANDs the test result with the RLO.":-stl programming manual
the value of RLO at/after step 2 is 0 then as per the def cited above the value after step 3. should remain 0 even if m0.1 is 1
also what is the value of RLO at the start of a network.i think it should be 1 irrespective of the value at the end of previous network, if the analogy of a network in stl is a rung in lad and the power rail is the start point of a rung.
there is a fault in my understanding but where?
thnx agn
hi ld,
i tried my best but still could not get any info on /fc other than
"* Bit cannot be evaluated in the user program with the L STW
instruction since it is not updated at program runtime."
but i think the answer to my question lies in
definition of jc
"If the result of logic operation is 0, the jump is not executed. The RLO is set to 1, and the program scan continues with the next statement.":stl programming manual
so at step 3 the RLO starts with 1;
anyway i would be grateful if you will share any info that you have on /fc
thnx
Hi all, I'm starting learning Siemens from scratch. I have to use a S7-300 Siemens PLC in a project. There's a change more pieces of equipment...
6,455
Currently tinkering with a home project for a wood router lift machine using some second hand parts from a redundant timber mill. The servo is a...
2,451
Hi Everyone I have a customer that would like me to add a KTP700(PN) panel to an existing S7-300 PLC. Since this is my first Simatec panel I...
1,688
Greeetings i do need to connect the control Teqniques Servo Drive digitax Basic to Siemens PLC i do use Profibus communication Module in the...
3,382
Hello I'am using TIA portal V11 SP2. My plc is a CPU315. I would like to make a small program to read a peripheral profibus Element in SCL...
2,535
