s7-300 and sew inverter
tulip
Oct 2005
ist
236
Dear colleauges,we have got a S7-300 plc and a SEW Inverter .Now there is a problem.When we give start to system firstly break enable signal come and motor must be on but at the start main enable signal come to sew inverter on profibus and no breake enable signal after that main enable signal is off automatically.I look to program but clearly dont understand and comment is French.And the other need is sew profibus protocol (control and status Word related) manual.Program is following...
Periphery address of this sew PIW256,PQW256 on hardware (6 DWord long)
OB1: (called FC25)
FC25's parameters:
VAR_ADR_READ=256 (INT)
VAR_ADR_WRITE=256(INT)
PROG_ADR_READ=100(INT)
PROG_ADR_WRITE=200(INT)
LONG=6(INT)
FC25:
VAR_ADR_READ.........>MOVE........>VAR_ADR_READ_W (WORD)
VAR_ADR_WRIGHT.........>MOVE........>VAR_ADR_WRITE_W (WORD)
PROG_ADR_READ.........>MOVE........>PROG_ADR_READ_W (WORD)
PROG_ADR_WRIGHT.........>MOVE........>PROG_ADR_WRITE_W (WORD)
After that ;
PROG_ADR_READ_W........>shift left Word 3 times.....>PROG_ADR_READ_W
PROG_ADR_WRITE_W........>shift left Word 3 times.....>PROG_ADR_WRITE_W
LAR1 P##POINTER_READ
L B#16#10 //Charger l'ID de syntaxe et
T LB [AR1,P#0.0] //la transférer dans le pointeur ANY.
L B#16#2 //Charger le type de données octet et
T LB [AR1,P#1.0] //Transférer dans le pointeur ANY.
L #LONG //Charger nombre d'octets et
T LW [AR1,P#2.0] //les transférer dans le pointeur ANY.
L 0 //Numéro de DB (ou 0)
T LW [AR1,P#4.0]
L B#16#83 //Type M
T LB [AR1,P#6.0]
L 0
T LB [AR1,P#7.0]
L #PROG_ADR_READ_W //Octet de début de transfert
T LW [AR1,P#8.0]
LAR1 P##POINTER_WRITE
T LW [AR1,P#4.0]
L B#16#83 //Type M
T LB [AR1,P#6.0]
L 0
T LB [AR1,P#7.0]
L #PROG_ADR_WRITE_W //Octet de début de transfert
T LW [AR1,P#8.0]
After that SCF14 and SFC15 is calling
LADDR:#VAR_ADR_READ_W RECORD:#POINTER_READ (in SFC14)
LADDR:#VAR_ADR_WRITE_W RECORD:#POINTER_WRITE (in SFC15)
Thanks in advance.....
Machine A has a Siemens PLC and ABB robots. Machine B has a PC control and not ABB robots. We are making machine B like machine A. I have the...
3,740
hello guys... Im doing a certain modification of depositing machine i will be using the following: seimens 315 - 2DP cpu MP 370 HM1 FM 352 cam...
5,355
Hi everyone! I'm just installing a SEW MOVIDRIVE B to be controled by a Siemens S7 300 using an ethernet (profinet) network. The hole network is...
12,047
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
18
36
