S7 300 CPU password protected
Canopener and sprot, as far as I know, can only unlock know-how protected blocks in the Step7 program. If the CPU itself is password protected, as far as I'm aware, the only person who can help you, apart from Siemens, is Andy Rothenbacher in Germany:
S.Rothenbacher GmbH
Benzstr.6 89079 Ulm
tel: 0731 45020
fax: 0731 46055
email:
[email protected] <mailto:[email protected]>
<http://www.rothenbacher-gmbh.de>
About four years ago he used to charge about 1100 € for removing the password protection, that may have changed since then.
S.Rothenbacher GmbH
Benzstr.6 89079 Ulm
tel: 0731 45020
fax: 0731 46055
email: [email protected] <mailto:[email protected]>
correct, i should have read the post more accurate.;)
is it possible to get the old type s7-300 cpu download password? I know we can get password from the mmc card, but the old cpu(6es73152af03...)...
1,658
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
144
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
188
Hi there, I have an application where I’m required to connect Siemens S7-300 PLC (Profinet) to Allen Bradley Control Logix Remote I/O Rack &...
3,691
i have 314 siemens cpu the machine stopped and all plc output modules doesn't give any output . i checked it and all modules are ok. when i...
3,307
