S7-300 cpu uploading
qamrij
Apr 2016
Milan
Good morning everyone and thank you in advance for your time.
I have a s7-300 plc that controls a production line, i have to modifya part of the program to block a motor that is connected in profibus. Well in shorts my question is if i don't have the project on my laptop, and i try to upload the program from the plc i will also see the connected peripheral devices in the hardware editor?
I don't have gsd files of the peripherals, will i see them in the hardware editor?
using step7
hello sir,
yes you can see them in the hardware configuration that connected to the profibus node, but you can't find the details of the module since you don't have the gsd.
only one incident when i tried to uploaded the program in the PLC and can't find it in the hardware configuration. The Micromaster 440, everytime i uploaded the program it will show a warning, that my software is missing a "drive ES /SIMOTION SOFTWARE, package. but all others like danfoss, SEW, phoenix module, and etc. it will appeared in the profibus node.
Thank a lot and yes the services s a sew movimot. I hope the node adress is the same as the motor number on the diagram.
In the course of trying to find out what was wrong with the 4MB MMC for my 317-2 DP CPU (see separate thread), I was repeatedly uploading...
15,806
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
121
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
Hi there, I have an application where I’m required to connect Siemens S7-300 PLC (Profinet) to Allen Bradley Control Logix Remote I/O Rack &...
3,659
i have 314 siemens cpu the machine stopped and all plc output modules doesn't give any output . i checked it and all modules are ok. when i...
3,304
