s7-300 Danfoss FCD300 Profibus DP V1
Boxy
Nov 2008
Sydney
57
I know there are already a few Threads with similar setups but i still think i'm missing something.
I have an S7-315PN/DP with ET200M's and Danfoss FCD300 VSD's connected via the profibus.
I have installed the GSD files, setup the HW config and have used the 2 Blocks supplied by Danfoss. One block just detects connected nodes and the other is for Parameter Assignment.
Where do I use this PCA block? OB1?
After this do i make changes the the values by writing directly to the PIW address?
Thankyou in Advance
Forgot to mention, you need to use sfc 15+14 if you want yourself make program that writes/reads staright from danfoss. with l and t instructions in s7 you can only transfer 1,2 or 4 bytes of consistent data.
Thanks TurpoUrpo. I have it all working now. You were a real help. I do have a question though, why is it 264? What does 256-263 get used for? the first bit of the PCD?
Is this the addresses say, a Function Block supplied from Danfoss would use to read and write parameters?
This was the first time I have worked with VSD's on a network, Remote i/o, Profibus and second time using S7. All makes sense now. Thanks heaps guys
I want to read voltage and current from a Danfoss drive FC300 with S7-300 PLC. I need help with the programming. Hardware bit has been done by OEM.
6,528
Hello experts, Maybe anyone of you who has experience working with Danfoss FC300 controlled over profibus, please share. My problem is...
3,030
dear automation experts, can we use the FCM300 for danfoss with an SEW motor? or it comes as a package motor/Drive only not seperable?
2,024
Hi I have little problem figuring out problem with this drive. Resistance between earth and phases is about 7Moms, is it enough? When problem...
27
17,057
Can anybody point me in the direction of a manual/insructions for using the smart logic functions on this inverter. I have a simple pumping...
4,510
