s7-300 hardware setup
rob63
Mar 2015
uk
69
When connecting a s7 setup - psu, cpu, input and output is the correct configuration of cables
PSU-CPU 24v and 0v mass
Input card 0v wired to terminal 0, the rest of terminals on the card are for inputs from sensors etc
Output card 0v to 0 and 24v wired to terminal 10
I don't have a sensor to test my input card is ok, could i link 24v over to the input terminal?
most input cards wire 0V on terminal 20 (+ on 1 but not always necessary), but you might have a card which doesn't? I think you should check this documentation.
you can wire a switch to an input, or just apply 24V to it to test
Hi, I'm using E300 as E3 Plus in emulation mode. E300 is Rockwell Automation's overload relay. But I get hardware fault when I enable Ground...
470
Hi, I have some remote IO connected to my S7-317-2 PN/DP system. I have 1 particular profinet remote IO which is not important to the system, and...
2,989
I'm setting up some E300's for an impending MCC upgrade, and I'm having some issues. I have the 193-EIOGP control modules, specifically...
1,334
Hi... Friends... I have s7-300 Plc that is password protected so I able to download n upload the programme,so please help me how to...
12,035
Hi, I got two questios: There are two slave devices(SEL-787) from which I should read data via MODBUS RTU. I checked SEL-787 manual and it says...
5,553
