S7-300 IP adress change without plc program
Jeff23spl
Jan 2010
Canada
860
Hello
Do some of you use a simple way to have the IP adress being changeable by the end user ?
I have an S7315 pn/Dp project where i did a commissioning last year very far from my office and now they are implementing a Scada system...
The IP i configured is probably out of their network range so i'm wondering if there is a way to have this adress changed without Step 7 and by the way giving my program acess...
unfortunately i didn't made the data reference availaible on the HMI screen...
By the way is their a simple way to connect 2 different ip network together to connect my IP range to their IP range ?
The easiest way in my mind would be to toss a router in between the PLC and the Scada system. Then just configure it to forward the packets between the networks.
sounds good for a router :)
I should someday take a class for Ethernet connection but i don't find any specific trainning class availaible when looking for it and i don't want to do a full degree on computer stuff to learn just what i need for plc programming issues....
Hi, why i can't change output adresses ? And how can i do this ? In STAT i have output adresses starting from 4.0, but it is also not possible to...
1,193
Can somebody explain me how to work with adress registers? An example would be very nice. Thx
1,994
52
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
53
45
