S7-300 Module diagnostic buffer
May 2004
25
I had an S7318-2DP perform an automatic memory reset due to inconsistant data. The following was the relevant portion of the diagnostic buffer (the dates are incorrect and are in reverse chronological order).
Event 58 of 100: Event ID 16# 4301
Mode transition from STOP to STARTUP
STOP due to: Memory reset started automatically (power on not backed up )
Startup information:
- Time for time stamp at the last non backed up power on
- Single processor operation
Current/last startup type:
- Automatic warm restart after non backed up power on (with system memory reset)
Permissibility of certain startup types:
- Manual warm restart permitted
- Automatic warm restart permitted
Last valid operation or setting of the automatic startup type at power on:
Previous operating mode: STOP (internal)
Requested operating mode: STARTUP (warm restart)
Incoming event
05:49:39:671 am 01/02/97
Event 59 of 100: Event ID 16# 430E
Memory reset executed
Initialization information: Memory reset due to inconsistent data
Previous operating mode: STOP (memory reset)
Requested operating mode: STOP (own initialization)
Incoming event
05:49:36:760 am 01/02/97
Event 60 of 100: Event ID 16# 4309
No relevance for user (Z1): 0001
Previous operating mode: No voltage
Requested operating mode: STOP (memory reset)
Incoming event
05:49:36:414 am 01/02/97
Event 61 of 100: Event ID 16# 494E
Power failure
Previous operating mode: RUN
Requested operating mode: No voltage
External error, Incoming event
09:13:44:411 pm 12/30/96
My question is this: The Plc had battery backup and FEPROM, so why would the plc perform a automatic memory reset and cause me to lose all of my hardware configuration and program? Where can I find more information on the Event ID's besides the text it gives you?
Marek
Hello, I have (probably silly) question about Kinetix 300. Do you have to manually send/save Kinetix parameters in the memory module and if so...
772
Hello. I have Cpu 315-2pn/dp and I have Lumberg 0970 PSL 701 DI/DO Module. I uploaded the GSD file, but I could not communicate. I think my cable...
1,847
I am working on a project to synchronize position for 4 cylinders using s7-300. Each cylinder has a resistor based transducer and each cylinder is...
2,299
Does anyone know about this RAE300.msi file needed for Studio 5000 to use an Ethernet module in the I/O configuration? I looked and ran the setup...
4,165
Hello dear experts! In my current project I have four Rosemount flowmeters (4-20 mA + HART) connected to AI8x16bit HART module (6ES7...
5,649
