S7 300 Module
Ger_gnu
Dec 2010
Buenos Aires
Hi:
I tell them we have a s7 300 with connexion MPI
We need ethernet connexion
So I buy CP 343-1.
The problem is w#16#3FC.No matter the location in the rack. As if to check the modules
FB76
//Get status of the module on the place 10 (analog input, dummy module or empty)
M09L: U DIX [AR1,P#1.2]
O(
L #DATEN[77] //Actual module typ
L W#16#8FC0 //Identification for a dummy module
==I
O(
POP
L W#16#C0 //Identification_1 for empty place
==I
//V1.3
O(
POP
L W#16#0 //Identification_2 for empty place
==I
SPB M0AL //Module rack 0 place 10 parameter has been Loaded
L #DATEN[76] //Nominal module typ
==I
SPBN WMTP //Wrong Module Typ on the Place
L W#16#A //Load modul place number
T #t_MODUL_PLACE
L B#16#54 //IOID-Number of the input module
T #t_P_IOID
L 280 //Basicaddresse of the module
T #t_P_LADDR
L B#16#AA //Filter time for input module (50Hz)
T #P_DATABASE.CHANNEL_CONFIG
SPA LDAT
M0AL: NOP 0
Best regards.
Germán.
Hello, I have (probably silly) question about Kinetix 300. Do you have to manually send/save Kinetix parameters in the memory module and if so...
770
Hello. I have Cpu 315-2pn/dp and I have Lumberg 0970 PSL 701 DI/DO Module. I uploaded the GSD file, but I could not communicate. I think my cable...
1,841
I am working on a project to synchronize position for 4 cylinders using s7-300. Each cylinder has a resistor based transducer and each cylinder is...
2,285
Does anyone know about this RAE300.msi file needed for Studio 5000 to use an Ethernet module in the I/O configuration? I looked and ran the setup...
4,144
Hello dear experts! In my current project I have four Rosemount flowmeters (4-20 mA + HART) connected to AI8x16bit HART module (6ES7...
5,627
