S7-300 MPI wiring to a TP370A
walrus_51
Mar 2003
Can anyone help me with a pin-out and wiring diagram to connect an S7-300 cpu MPI port to a TP370A HMI? Siemens UK are out of stock of ready-mades!
Shell to Shell
Are you sure that's not hermit crabs that do that?
hehehehe.. sorry (my bad sense of humour)
What goes from shell to shell?
Walrus.
The shield of your cable should be tied to the shell of the DB-9 connector at either end. I use the Siemens connector part # 6ES7-972-0BA41-0XA0. It has a built in terminating resistor switch. Inside the shell is a place where the shield gets crimped.
MPI uses the same connectors as Profibus, also the same cable, if you like. As paraffin power stated pins 3 to 3 and 8 to 8.
I have not worked with a TP370, are you sure that you want to use MPI for communications not Profibus DP? Just a thought.
Paul
Hi all, I am trying to communicate S7-30(CPU 315-2-DP) with proface HMI, Communication has been established while reading MW,Memory bits...
1,315
So we have a large project kicking off, ripping out an old S7-300 and replacing with AB. We need both systems to run in parallel whilst we...
1,757
Hi All I want communicate PLC S7 300 by pycharm and use Libnodave pass usb mpi Can do it? If can please guide me (exemple of script python) Thank...
1,966
  • Poll
I am beginner for PLC programming and I have cable s7 300 USB/MPI cable but unable to find drivers for that cable . Can any one help me to find...
3,091
Hi All, For some days now I have been working on a pass-through link with my Weintek CMT-SVR and Siemens S7-315-2DP. Hardware: Weintek...
6,950
