S7-300 to Kepware via MPI
janner_10
Dec 2014
Tewkesbury
1,301
So we have a large project kicking off, ripping out an old S7-300 and replacing with AB.
We need both systems to run in parallel whilst we gradually migrate from one system to the other.
Kepware is sitting between the 2 and working very well.
Is there a way to export the tags from the Siemens into the Kepware aside actually adding them manually.
The Siemens seems to export in .asc whilst the Kepware wants .csv?
Is there another way?
I appreciate your reply, but we are the familiar with the AB side and not the old Siemens side.
I got there in the end with a lot of copy and pasting and d!cking about.
PS I hate Siemens!
Hi, I am trying to connect kepware OPC server to S7300 PLC. The task is to read Data block DB40 into OPC. As it is my first experiance with...
8,664
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
37
39
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
176
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
146
