S7-300 opn db
jwilcoxson
Sep 2014
Georgia
31
Hi everyone,
If I am writing a S7-300 program in STL, why would I need to use
Code:
OPN DB2
L DBW1
when I could use
Code:
L DB2.DBW1
Ok, so maybe I would just use OPN if I was going to use the particular DB several times and wanted to save myself some typing?
Please be aware that there is an implicit OPN with any fully qualified DB access. In the example below, the transfer will write to DB2, not DB1
Code:
OPN DB1
L DBW 0
L DB2.DBW2
+ I
T DBW 2
Thanks, that is really good to know, I wouldn't have assumed that. So that means that this:
Code:
L DB2.DBW1
Is exactly equivalent to this
Code:
OPN DB2
L DBW1
Code:
L DB2.DBW1
Code:
OPN DB2
L DBW1
That is correct.
I believe that
Code:
L DB2.DBW0
L DB2.DBW2
is also the same as
Code:
OPN DB2
L DBW0
OPN DB2
L DBW2
You might theoretically save a tiny bit of processing by using OPN, but it is negligible. Most people find that using the fully qualified name (DB2.DBW0) is much clearer and easier to read. The hardest part of STL is making code that other people can follow. I think there are a very few specific situations where using OPN allows you to do something you couldn't program other ways, but most of the time I think people prefer the DB2.DBW0 style.
Execution time and memory useage may become important to you at some stage. Using DB numbers 255 and below also uses less memory.
Code:
OPN DB1
L DBW 0
L DBW 2
+I
T DBW 4
uses less memory than:
Code:
L DB1.DBW0
L DB1.DBW2
+I
T DB1.DBW4
One important note.
With "OPN" etc. you wont have any symbols, apart from the DB symbol.
Code:
OPN "myDB"
L DBW 0 // absolute addressing !
L DBW 2
+I
T DBW 4
Code:
L "MyDB".MyINT1 // symbolic addressing !
L "MyDB".MyINT2
+I
T "MyDB".MyINT3
IMO the eventual gain in execution speed is far less important than that abolute adressing is more error prone and more difficult to maintain.
Btw. You can program symbolically with SCL, and the SCL compiler will take of when to use "OPN" in the generated STL code.
You need to try the different examples listed above in debug mode
You can see the DB register gets changed with the OPN DB1 or with the L DB1.DW0. The DB register stays the same until changed again.
L D[AR2,P#0.0], I forget. What restores the DB to the original state after a return from a call? Upon entering a FB or FC I would save the old DB away if I needed to change it and restore the DB before returning so that it would be in its original state.
55
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
54
45
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
183
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
150
