S7-300 power consuming
engineerjaber
Sep 2013
Ramallah
23
Could anyone please help me how to find or calculate the total power consumed by S7-300? so as to i can determine the UPS KVA rating.
The same as for GE RX3i.
Dear all, My CPU312 is in RUN state, RUN and DC5V LED's are green. Still there is no input or output. CP341 (RS422/485) is also installed in a...
1,058
Hi, I'm working on a project where we will use a CPU 314C-2DP with 2 built in IO cards, 1 x SM331 AI, 2 x CP341 and 1 x CP343-1 Lean. Will each...
1,525
My screen was damaged, so I ordered a new screen, I installed it. It says its booting. Then a fault comes up ' the CF card and the PP45 are...
1,122
Is there any reason I can't just use a regular 24VDC power supply to power an S7-300 series rack? From what I see, the only connections between...
3,792
Hi guys, I have a client wich keeps telling me to give him a solution to his problem. The problem is that he has an automation with a S7-300 and...
2,982
