S7300 CPU312 Rack power issue
Arizona
Mar 2020
Pakistan
32
Dear all,
My CPU312 is in RUN state, RUN and DC5V LED's are green. Still there is no input or output. CP341 (RS422/485) is also installed in a rack with other I/O modules. I figured out that there is a power failure in all cards except main CPU because all the indicating lights are off only CPU is energized.
Any suggestion please??
Dear all,
S7-300 cards often have separate power from the main CPU. Power must usually be wired to each card.
I'll confirm it once I'll be on site. If they have separate power then will go for the troubleshooting of power supply.
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
116
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
179
Hi guys, I'm having problems converting WinAC (WinLC RTF F application) to S7 300 project based on CPU 319F-3PN or S7 400/416F-3PN. The problem is...
615
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,009
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,066
