s7 300 redundancy problem
pauly
May 2002
South Wales,U.k
244
I am having a problem with an S7 300 and the redundant connection. Everything has been working fine until I changed the config on the analogue output cards in both processors.Now I am seeing a return value at FB101 alternating between
16#8015 and 16#0000 in the master cpu and a return value of 16#8018 in the standby cpu.
Any ideas anybody?
Hello! I haven't worked with software redundancy before, so I was wondering if I could use the CP343-1 Lean modules (which I'm using for the...
1,770
Dear Experts, I am working on a system with S7-300 software redundancy due to high availability requirements of the control logic. My question...
2,114
Can someone help me about using S7-300 CPU's for redundant application for example 315C-2DP or other kinds. thank you
1,424
Anbody ever used S7300 with the software redundancy blocks FC100, FB101 etc? I am told that the declaration of IEC timers and associated DB's...
4,055
Hey Ladies and Gents, I'm new to PLCS.net and have a problem with working with the software redundancy of Siemens. What I have: 2 - 315-2...
18,246
