S7-300 "RUN" activated but program not running!
ian329
May 2011
s
I have setup an S7-300 CPU312(32MB) in Step7 Lite.
Have done the following...
* Configured the hardware: CPU312C in Rack0, Slot 2
* Setup three symbols: "TEST_IN" = I124.0, "TEST_OUT" = Q124.0, "TEST_OUT_2" = Q124.1
* Created OB1:Main_Program
* Drawn ladder logic in OB1, which equates to the following in STL:
Network 1:
A "TEST_IN"
= "TEST_OUT"
Network 2:
AN "TEST_IN"
= "TEST_OUT_2"
I Download everything to the CPU and switch to RUN. The diagnostics show that the CPU is RUNNING with no faults, however I would expect the LED next to output Q124.1 to be lit, until I apply 24V (from same power source as CPU, a PhoenixContact 24v 10A PSU in this case) to I124.0, in which case Q124.1 would go out and Q124.0 would light.
Looks like my program isn't running. Any ideas why?
Cheers
Ian
Hello, I have a problem with Kinetix 300. One, small machine (cake cutter) has two Kinetix 300 drives to spin the cakes (one drive - one cake)...
1,781
G'day guys, I am setting up a s7-300 as a test rig for the workshop and when I downloaded the PLC is not going into run mode, I keep getting a...
35
5,229
Hi, I have some remote IO connected to my S7-317-2 PN/DP system. I have 1 particular profinet remote IO which is not important to the system, and...
2,987
Hello, I am using Kinetix 300 with CompactLogix (Ethernet IP) and it works well, but happened twice along one day the following situation: I...
1,983
HMI Can't start to RUN mode. - - HMI after RS422 Chip replace - - Question- what I should to do to go to RUN MODE Cable - original after Ports...
2,966
