S7-300...SFC60 command
f117
Oct 2007
ath
26
Hello i need a little help with siemens step 7....I have made a connection point to point communication with ASCII.The problem is that when i use SFC60 to send datablock it is limiting the size of data that is send to 36 bytes.how can i send up to 206 bytes like the manual says?and i could be greatfull if you can tell me an example with that command!
Thanke you
I sense some confusion here.
SFC60 is used for "Global Data" via MPI.
Point-to-point communication is somethings else, if you mean that you have a CP340 or CP341 module for example.
Please provide some more details.
In case that you really mean GD data via MPI, then it says in the manuals that I can find that Global Data is limited to 22 bytes for S7-300 and 54 bytes for S7-400.
Where do you see that you can send 206 bytes ?
Anyway, for larger amounts of data via MPI, you could send data via several SFC68 X_PUT jobs, 76 bytes at a time for S7-300.
i am sorry...my mistake...i meant SFB60 not SFC60...!in that case what is going on?thank you for replying
I have no experience with a CP340.
Because your thread title is misleading you should start a new thread with a proper title.
Be sure to include "CP340" and "ASCII" in the text.
something else now....can you tell me if you know how i can set initial values to an instance data block that is used by the SFB60 ....... thank you
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
147
123
284
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
74
83
