S7-300 ->Support device replacement without exchangeable medium, meaning?
naturephoenix
Jan 2015
Vienn
181
Can some explain me what's the measining of this option inside hardware configuration.
When should I want/need this option to be on/selected and when should I want/need this option to be
off.
Funnily enough i have just spoken to someone from Siemens about this, as when i compiled an existing project i received a warning:
Warning: The "Replace device without exchangeable medium" function cannot be used for IO device.
What does this mean if i downloaded the project?
Normally, when a Profinet device needs to be replaced, the new device needs to get the device name assigned before it will talk to the PLC. Normally this would require you to get your laptop out.
Some devices simplify this by having memory cards that you can move from the old to the new, that carry the device name over (device replacement WITH exchangable medium), no laptop required.
If the device supports it, and this option is checked, then the PLC can automatically assign the device name. The PLC knows that a device of XYZ type USED to be connected to the network at the end of this cable. When a new device of the same time (usually at factory default comm settings) shows up at the same place on the network, the PLC recognizes that it is the "same" device, assigns the name, and then they are up and talking.
32
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
174
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
144
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
218
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
117
