S7 300 to S7 200 ethernet
JOLTRON
Aug 2006
MI
692
Is it possible to send information from a S7 300 plc to a 200 series plc thru ethernet. I have an add on machine that I would like to send a part number, and pass/fail information. I would like to have it entered into the datablock maybe in the V memory.
Thanks,
Thanks,
You will find configuring the ethernet communication from the S7-200 to the S7-300 far simplier than other way around.
MicroWin has an Ethernet wizard that guides you through the steps. Step7-300, without the manuals and a lot of patience, good luck.
Step 7 MicroWin for S7-200 was developed in US, whereas Step 7 for S7-300 was developed in Germany. American software is always more intiutive and user friendly.
Ian
Ian
I heered that. Got the t-shirt and a key chain.
Alrighty, I have the basic concept of how it works. My next question is, If I am using the S7-200 series PLC to "GET" information from the S7-300 series, how do I specifie that I want to pull it from a specific address (ex P#db200.dbx40.0) Or the other way around how would I "PUT" it into a specific VB from the 300 to the 200.
Thanks,
-Joel
Thanks,
-Joel
The ethernet wizard in MicroWin steps you through the procedure. In S7-300 you need to configure a connection # that the MicroWin will use in the wizard.
While I'm setting up the connection in the S7200 it is asking me where it would like to pull the data from. This looks like it needs to be a type of VB (Ex: VB3) but the S7-300 uses DB's as DB501.dbx0.0 How do i get around this?
Thanks,
-Joel
Thanks,
-Joel
Try this link to Siemens support.
It has step by step instructions
Thanks alot man. It was the TSAP that was confusing me. Got her all cleared up now.
I have a project with an S7-300 and several S7-200s that need to initiate peer to peer communications via ethernet. My issue is the Siemens...
3,791
Hi.In the S7-300 plc, DB100.DBB10, whose data type is byte, is transferred to db23.dbb10, whose data type is bool, with the move command. This...
813
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
767
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,782
Hello everyone, I have a SIMATIC s7-300 CPU 313-2 DP[ORDER NO:6ES7 313-6CF03-0AB0] with firmware version 2.012. I want to update the firmware with...
2,073
