S7-300 Write to file, Read from file
Tarkmees
Feb 2007
Harku
Is it possible to write DB fields into a (comma separated) text file? And read them back again ... If yes, how to do it?
PLC Siemens S7-319.
Thank you.
From Step7. But we have 7 OP-panels in the project too, connected via ethernet. I'm at home now, so I don't know the exact type, but they are two types. Bigger and smaller touchscreen panels.
Where are the CSV files ?
On the OP panels, or on a PC networked with the PLCs/OPs ?
edit: And what is it that you want to achieve exactly ?
The CSV files are on a network computer. Same computer where Intouch visualisation is running.
Purpose of this thing is that customer wants a daily backup of all product data in the building (about 100 000 DB fields). These products are stored in tracks. Customer wants to be able to do a 'trackwise' restore. So write back saved data into the PLC.
This customer wish comes from their experience with a previous system where PLC data obviously disappeared once in a while.
We tried to talk them out of this option because it is probably not necessary, but they want it anyway.
I am trying to write just MSEC to S7 300 Controller date/time using OI.SIDIRECT Aveva communication driver? The old HMI (WINCC) tag is assigned...
1,068
One of our customers has a Siemens S7-300, CPU 315-2DP PLC which they want to load a recipe into. The recipe is generated in Excel. Does...
17
6,973
Hi Sir, I am using S7-300/400. I am usually using FC 03 and FC04 to transfer (R/W) bool values by moving them DBs. However i want to R/W bool...
2,076
I'm sure there isn't any official documentation, but is there any resources out there on how to write in OB/FC/FB blocks in to a S7-300 PLC...
1,605
Sir, At present i can write one parameter at a time, but how to write multiple parameter in sinamics s110 using SFC 58 in S7-300. And also...
2,388
