S7-300
COWBOY
May 2003
Hello,
Can anyone tell me how to transfer data blocks from one S7-300 to another S7-300 via MPI.
COWBOY
The easiest way is to use SFC67 (X_GET) and SFC68 (X_PUT).
On the DEST_ID pin put the MPI address of the partner CPU (e.g 16#3)
On the VAR_ADDR pin, use the 'any' pointer to define where the data is to be put in the partner CPU (e.g P#db1.dbx0.0 byte 8)
On the SD pin, again using the 'any' pointer put the place where the data to be transfered is stored.
What I have described there is for SFC68 (X_PUT)
SFC67 is slightly different:
VAR_ADDR - any pointer - the address on the partner CPU where the data to 'get' is stored
RD - any pointer - the address where you are going to store the data got from the partner CPU
Hope this helps
Paul
Hello, Cowboy;
You can use the SFC65/66, X_Send/S_Rcv, to exchange data between S7-300/400 CPUs over "Unconfigured" MPI connections. This means that in the parameters you must enter the MPI address of the partner CPU and a job identification number for the coordination of the data exchange.
One suggestion: for the SD and RD parameters, use a ANY pointer in byte format; this seems to cause less errors for the exchange of data;
for example:
SD (send data info)= P#DB10.DBX0.0 BYTE 64
translates to "send 32 words of data starting at the first bit of the first byte of DB10". Check on the format of the ANY pointer in Step 7 help if this is confusing.
Hope this helps,
Daniel Chartier
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
112
120
282
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
66
81
