S7 312 program lost after power failure
Thim
Mar 2008
Belgium
392
Hello folks,
First of all a happy new year.
I have a question, about a S7 312 5AC00 0AB0.
Everything works ok but when the power is lost or shutdown the downloaded program is lost.
I know simulair questions has been asked before but i don't seem to find it back.
Someone knows how i can download the program so it stays in the PLC when power is lost.
Hello folks,
The memory is a little different on those cpu's.
Have you done a "ram to rom" ?? from Step7
SIMATIC S7-300 CPUs and SIMATIC C7 devices with built-in RAM and EPROM as load memory In the case of CPU modules that have a built-in EPROM you can use the "Copy RAM to ROM..." function to copy the content of the internal RAM load memory to the built-in EPROM load memory so as not to lose data in the case of power failure without battery or overall reset. In the case of SIMATIC S7-300 CPUs or C7 devices with internal EPROM as load memory the code and data blocks are written from the RAM load memory to the EPROM load memory.
http://support.automation.siemens.com/WW/view/en/24168030
Thx
No i didn't tried it yet, i will give it a try.
I think it will do the trick because was just reading the same stuff in another S7 Manual :)
Hello, I've got a strange problem with S7-312 IFM. I've uploaded a PLC program, made changes in one of fc's, and downloaded fc back to plc...
1,829
Hello my fellow plc masters. I have come to ask you again :D Lets start the story. A few days ago i've made a post here about a s7-300 plc and...
19
4,587
Hi! Greetings, I've been trying to use the PLC M221 to control and read the variables from the VSD ATV312 through Modbus RTU, which is something...
1,609
Dear all, My CPU312 is in RUN state, RUN and DC5V LED's are green. Still there is no input or output. CP341 (RS422/485) is also installed in a...
1,059
As you know, Schneider is phasing out the 312. We have had problems w/ the 320 following the decel ramp. Anyone else? Also, we have had to adjust...
1,543
