Connection between M221 and ATV312 Modbus RTU
Catzu
Jun 2020
Rondônia
Hi!
Greetings, I've been trying to use the PLC M221 to control and read the variables from the VSD ATV312 through Modbus RTU, which is something I've never tried before. I've searched a bit and found a topic regarding the matter (http://www.plctalk.net/qanda/showthread.php?t=99112) as well with a pdf file (https://www.se.com/ww/resources/sit...21 et un variateur ATV12 ATV312 et ATV32.pdf). I've followed the procedures within the best of my abilities but unfortunately, I didn't succeed in my attempt to read or manipulte the variables from the VSD.
I believe the issue is that I lack basic knowledge regarding the Modbus RTU protocol as well using and manipulating the external variables.
Would someone help me to underestand? And if possible, if you can guide me to something I can use to study for myself since I've haven't found something that indeed works in my reseaches.
Setup I am using:
Software:
EcoStruxure Machine Expert - Basic
PLC:
M221
speed: 19200 bps
parity: par
timeout (x100ms): 10
adressing: master
ATV312:
speed: 19200 bps
format: 8E1 (8 data bits, parity even)
adress: 1
Never done it but one thing you might bear in mind is sometimes data sent or received might be byte reversed, so HE1A3 might be sent as HA3E1 worth a thought.
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
329
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
241
Good Morning, I got an IMO HD2 inverter with 2 slots and on the first slot I put the ethernet module (HD2-E-ENET) and the second one is free...
1,274
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,241
Hello, I'm gonna try to make this as clear as possible. For a project, we have 3 Unitronics PLC's controlling each a machine. The company that...
3,425
