s7 314 MPI TS/ PC
bly
Oct 2003
Hi ppl
Any help out there ?
A week ago my laptop was stolen along with cables, mpi adapter,
software ect.
I have since purchased new laptop and serial cable( direct connect)
re/loaded step7 5.3 . We had a spare mpi adapter(ts) but when i try to communicate with s7 314 i get message "adapter damaged or no connection " there is power light on the adapter but no activity light
ps Is mpi ts ok to use directly with pc and serial cable
ANY HELP APPRECIATED
T.I.A
Hello BLY;
The TS-adapter (TeleService adapter) is for modem connections over PSTN between a programmer PC and a S7 CPU, not for direct link from COM port. See the following:
For direct connection, you need a PC-adapter.
Hope this helps,
Daniel Chartier
Check your PG/PC settings that you use direct comunication and the transmission speed is the same as the TS-adapter.
Check also a little dip-switch at a TS-adapter that the transmission speed is a same speed as your com-port.
My TS-adapter works with 19,2 kbit/s.
Hope that you get your adapter working...
I think TS-adapter is very "handy" because you can use it modem communication over the phonelines or direct connection to the plc.
I was involved once in a project, where a TS Adaptor was used for both Modem link and direct connection, IIRC the connection cable between adaptor and pc is different to the RS232 version for the PC Adaptor.
The RS 232 cable is the same. Have you installed the TS software and LICENCE? Once you do, you can go to the configuration and select direct connection. This is also where and how you configure the TS adapter for auto re-dial, initialization string, etc. The TS adapter can be used local or remote.
Re: Ts Adapter
Cheers
all for the quick answers
I believe that you can use this adapter for direct connection
but to save any confusion between the other engineers on site
i opted to buy a pc adapter "PROBLEM OVER"
ANYHOW THANKS PPL
BLY
Hi, Previously, we have used Red Lion Kadet units connected to S7 300 compact series PLCs via the Helmholtz MPI adaptor. We have now changed to...
4,811
I am new to using the Proface touch panel. Currently for a project i need to link a Siemens S7-314 PLC with the Proface 5.7" Touch panel...
7,188
:scratch: Hi everybody, Can anyone explain how to change the MPI address on these plc/cpu. I can change it on the offline program but I'm unable...
1,799
Hi, One our customer is asking if we can put a second operation panel to their "old" machine. "Old machine" consist S7314 CPU and OP7 connected...
3,632
P
Hi all. I have a CPU314 (no DP!) and a OP17. Is it possible to set the leds on the OP and read the keys when both are connected over MPI ...
4,102
P
