S7-315 Lock-up
Tom Jenkins
Apr 2002
Milwaukee, WI
6,301
Help! We are doing our first Siemens S7 project. We are using a 315 CPU, and programming with Step 7 Ver. 5.2 software in Windows XP Professional.
We established communications between the programming laptop and the CPU and tested a small program successfully. Then we configured the analog I/O card to match the part number of the one ordered. Unfortunately, we failed to notice that the card shipped was the wrong part number, and didn't match.
Now the CPU is locked up, we cannot re-establish communictions with the laptop, and the software error message is "Online communication to the program adapter failed."
Power cycling and rebooting the laptop, power cycling the PLC, and reset using the keyswitch have not helped. At this point we are dead in the water, and our supplier's tech support guys are all out for training or otherwise unavailable.
Is there another way to reset the CPU, or any other suggested recovery techniques?
Update
Through persistance and creativity, my PLC expert Tim was able to get communications back to the PLC. This was done by donwloading an incorrect configuration to the communciatiosn adapter (6ES7972-0CA23-0XA0) and then downloading the correct configuration.
However, there is still a major problem. Tim can download and upload function blocks, but he cannot access or upload or download the OB1 file, which is apparently the main logic organization file.
Suggestions?
CPU stop. Open a project at blocks level, then PLC-->Clear/Reset
Thye CPU should do an over all reset by turning the key switch fully CCW and hold until the light blinks 2 times. Release and then switch CCW 1 more time. Then release.
Thanks guys - Tim has us back in control of the PLC. We did get the reset cycle to work, but we still had problems downloading the OB1 file. I'm not sure why, but he was finally able to download a simple one input turns on one output ladder, and then we were OK. We can now download our "real" application.
Hello everyone... I'm working on a project where I want to use the time of the PLCs to do a specific process. In both PLCs (cpu 224 & cpu 315)...
4,345
I have OB35 created. I inserted Cont_c in rung, addressing it to DB1. Info: My A/I address starts at 448 and ends at 463. I set channel 1 to...
1,664
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
63
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
176
Hi , Looking for some help. We have a 343-1 PN Lean Card & 315-2DP connected to an external system collecting data. After a recent shutdown...
70
