S7-3xx 2DP PB --> Ethernet --> PB ET200s
Greg Fowlds
Apr 2004
Currently, Waiheke Island, NZ
123
Trying to find some converter to do this.
One end: (S7-3xx 2DP) Profibus DP to converter to Ethernet cable
Other end: Ethernet cable to converter to Profibus DP (ET200s)
Reason is that there is ethernet running between two pieces of plant now and I need to add a profibus DP cable which will be a nightmare to run so would like to try and use the existing ethernet connection (Ethernet->Fiber->Ethernet) and run the Profibus DP through it.
Been searching but getting confused with terminology of different devices that may be able to handle this.
Some seem to only handle PB to ethernet but not back.
There is profibus to fibre converters. Is there free fibres in cable that can be used?
Is that ET200s already installed?
Hi all, I now need to wrestle with a Lenze Servo Drive 93xx and the PLC within it. I have Global Drive Control & Global Drive PLC Developer...
2,417
1768-L43 Local rack was expandable in to a 2nd Rack via an expansion cable. For an example; PS ENET CPU I/O I/O I/O I/O [Expansion Cable] -...
1,562
Topic says it all. We're hunting around for a CompactLogix that works with older RSLogix but wondering how soon (if at all) AB will phase out the...
3,587
I recently aquired an ICP DAS brand USB/CAN converter, model: I-7565-H1 to communicate with my 2 Lenze 9326 servo drives. These drives are a part...
4,949
Hi there, I have spend the last 2 days trying to add 2x CLV630 barcode scanners by Erwin Sick to the hardware configuration of my 315-2 PN/DP cpu...
7,053
