S7 array element copy pointer problem
spaderkung
Aug 2007
South Sweden
389
Hi!
I modified some code, probably from member LD, to make a function
element := ReadFromArray(firstElement : ANY, offset : INT)
It seems to work fine as long as the array is an array of complex UDTs (the reason I wrote it). But for elementary arrays ([0..10] : INT) or ([0..10] : UdtWithOnlyIntMembers) it fails. The reason is that although the ANY.TYPE = 5 (INT) the ANY.NUM (repetition factor, size) = 1 where it should be 2 (bytes).
I had to modify the code to check for any elemental type, but I wonder why I did not get it to work the first time.
I run it on ACControls soft PLC, but I think I have also tried it on a 317.
Code:
FUNCTION FC547 : VOID
VAR_INPUT
//  BaseAddress : ANY ;
  SrcElementFirst : ANY ;
  SrcElementIndex : INT ;
//  DstElement : INT ;
  DstArea : ANY;
END_VAR
VAr_output
    srcNUM, dstNUM, retVal : INT;
    srcTYP, dstTYP : BYTE;
END_VAR
VAR_TEMP
    iSFC20Return : INT ;
    pSrc:ANY;
    pDst:ANY;
ViewSrc AT pSrc:STRUCT
    // This order is the S7 pointer format of 10B
    TYP:BYTE;
    NUM:INT;
    DBN:INT;
    PTR:DINT;
    END_STRUCT;
ViewDst AT pDst:STRUCT
    TYP:BYTE;
    NUM:INT;
    DBN:INT;
    PTR:DINT;
    END_STRUCT;
END_VAR
    pDst:=DstArea;
    pSrc:=SrcElementFirst;
    // Problem with elementary types? Or just soft-plc?
    // But an INT, with type 5 gets NUM 1 == only 1 byte size?
    IF ViewDst.TYP = 5 OR ViewDst.TYP = 4 THEN
        ViewDst.NUM := 2;
    END_IF;
    IF ViewDst.TYP = 6 OR ViewDst.TYP = 7 OR ViewDst.TYP = 8 THEN
        ViewDst.NUM := 4;
    END_IF;
    // No modification to pDest
    // Add offset TO pSrc
    ViewSrc.PTR:= ViewSrc.PTR + ViewDst.NUM * 8 * SrcElementIndex;
    ViewSrc.NUM:= ViewDst.NUM;
    iSFC20Return:=BLKMOV(SRCBLK := pSrc, DSTBLK :=  pDst);
    srcNUM := ViewSrc.NUM;
    dstNUM := ViewDst.NUM;
    srcTYP := ViewSrc.TYP;
    dstTYP := ViewDst.TYP;
    retVal := iSFC20Return;
    //dbg out
END_FUNCTION
The number in the Any pointer is always the number of elements and this is not necessarily the number of bytes.
Code:
VAR_INPUT
  DstArea : ANY;
END_VAR
VAr_output
END_VAR
VAR_TEMP
    pSrc:ANY;
    pDst:ANY;
    iByteCount:INT;
    TYP:BYTE;
    NUM:INT;
    DBN:INT;
    PTR:DINT;
    END_STRUCT;
    TYP:BYTE;
    NUM:INT;
    DBN:INT;
    PTR:DINT;
    END_STRUCT;
END_VAR
    pDst:=DstArea;
    CASE BYTE_TO_INT(ViewSrc.TYP) OF
        2,3:iByteCount:=1;
        4,5:iByteCount:=2;
        6,7,8:iByteCount:=4;
    END_CASE;
    ViewSrc.PTR:= ViewSrc.PTR + ViewDst.NUM * (8 * iByteCount) * SrcElementIndex;
    //dbg out
END_FUNCTION
Thanks. Ofc on the repetition factor...
But with arrays of complex UDTs (mixed elementary types) the TYPE shows as 2 (and NUM is correct as the total size in bytes), so I need to stick with my original modification.
Hello all, I apologize for the lack of code here. This is more of a basic idea I would like to try. This is my first time dealing with SCL and...
22
13,104
Hello, first time poster here! A belated "thank you" for the direction I've already received from this forum! So, can I do this? Move value 1...
725
I received the following message via PM, and am posting here publicly to help others. ============================================ I had a...
1,026
Hi Folks, I am trying to trend in Logix Designer an element of an INT[223] input data array. For some reason, the "add" button is greyed out. I...
2,195
I have 23 Micrologix 1400s and I want to take the same register, N100:99, out of each one and put in a single array in a CompactLogix L18ER. From...
18
7,009
