S7: Evaluate bit pattern
Hedeby
Oct 2011
Give
Hello
I need to know how many input are true from at 5-bit pattern.
The True/False sequence is random.
The evaluation has to be in every scan, so a counter is not an option.
Is there a easy way of calculationg that?
Here's an FC
Code:
FUNCTION FC 2 : INT
TITLE =
VERSION : 0.1
VAR_INPUT
  Bit0 : BOOL ;
  Bit1 : BOOL ;
  Bit2 : BOOL ;
  Bit3 : BOOL ;
  Bit4 : BOOL ;
END_VAR
BEGIN
NETWORK
TITLE =
      L     0;
      A     #Bit0;
      JCN   s0;
      +     1;
s0:   A     #Bit1;
      JCN   s1;
      +     1;
s1:   A     #Bit2;
      JCN   s2;
      +     1;
s2:   A     #Bit3;
      JCN   s3;
      +     1;
s3:   A     #Bit4;
      JCN   s4;
      +     1;
s4:   T     #RET_VAL;
END_FUNCTION
Why Not ? Use a int as a counter register
Code:
Counter=0
If bit 1=1 then counter+1
If bit 2=1 then counter+1
If bit 3=1 then counter+1
If bit 4=1 then counter+1
If bit 5=1 then counter+1
NoOfBits=Counter
Does anyone know how to do this logic in Contrologix?
1,572
Hi there, I have never used Citect before and have a few bugs to fix. I have 2 questions: 1. How can i view the tag database as a whole...
3,450
Hi all, I'd like to know your point of view on this aspect of PLC programming, the example I use is simple, but the concept can be applied to...
2,478
Hi I am having som problems evaluating if the value in an integer created in the Static area, is Odd or Even. As far as I remember, Odd integer...
17
8,438
Hello, I wrote some vba code for a Factorytalk View Studio SE application display. The code should be around 100 lines long using something...
1,966
