S7-GRaph question, Lenze positioning in a graph...
userxyz
May 2002
any
2,768
I have a problem with Lenze positioning via the AIF interface. I control the 15 ECS drives (application version 1.3) with a 317 Siemens CPU on a profibus network.
The problem I see is that the lenzes are sometimes in a positioning state with a previous position. So I'm thinking the weirdest thing now.
Can it be that an arithmetic action is processed in a later CPU cycle then the Rising Edge (S1 S) ?
The only possible explanation is that the position is send later then the start command, not in the same cycle... Is this possible ?
Action S1 S means: As soon as step comes active the adress state is set to 1 and remains 1 ( Difference is manual is the word Enters state)
With Action N: when step is active the signal state of adress is 1
So maybe try S1 N
I don't know if this would help you
mmm
So maybe try S1 N
I'll make them all S1 N, should do the trick if that's the problem.
As extra info screens of the manual
I wouldn't know for the other parameters, but if it doesn't hurt anyone, i would say give it a try đź“š
Extra info
Before you continue read this if i understand it well then the S1 action is readed like and event.
So when this event comes active it is been detected as a edge and excecuted except when there is an interlock then this interlock should be true also
I can't test it at this moment scince i don't have graph installed at this pc
Hello, What are Permanent pre-instructions and Permanent post-instructions that you can program in the Tia Graph FB's ? Thanks, kind regards, G
1,781
As i am newbie in S7 Graph, could anyone please explain me what is doing monitoring function in S7 graph.What is supervision line and required...
1,878
Hi all, As you know there is a S_NO Output parameter after compiling. You can connect an integer to it so that you can monitor the actual...
1,421
Hello Folks! I have an issue and its very often but in this case i applied all the tricks and tips that i always do in similiar issues but in this...
783
Hi all - Considering using S7 GRAPH for some sequencing. I have a few questions which I am having difficulty finding clear answers to in the...
583
