S7 GRAPH Questions
kdcui
Dec 2007
USA
386
Hi all -
Considering using S7 GRAPH for some sequencing. I have a few questions which I am having difficulty finding clear answers to in the Siemens documentation. I have experience using SFC on AB / RA systems but there is a bit of a learning curve to Siemens.
I could likely program everything I need in ladder much quicker but trying to a) learn something new and b) GRAPH may arguably be easier to troubleshoot for complex sequencing, so I'm thinking a bit about future ease of maintenance.
1. I've heard GRAPH takes a toll on scan time. For a S7-1515 CPU (working in TIA Portal v18) in a process control application, would this be something to be overly concerned about?
2. Can another GRAPH routine be called from within an Action? For example, Step 5 Action of fbSequence1 calls fbSequence2. The alternative seems to be to just create a new sequence inside the original FB but it "feels" more modular to have another block per sequence.
3. If I interrupt a GRAPH sequence (before it reaches the end), can I automatically resume at another step other than the Initial Step? If not, is there is built-in means to track active step, or should I just create a "CurrentStep" tag and update it programmatically?
4. Similarly, if a GRAPH routine is interrupted, how difficult is it is to re-initialize to avoid any "weird" behavior if I re-call the sequence?
Thanks.
Hi, I've just started trying to use S7-Graph and finding some of the features a little confusing. For example, each step can be configured...
4,520
Hello Folks! I have an issue and its very often but in this case i applied all the tricks and tips that i always do in similiar issues but in this...
778
Can someone explain the order of processing the actions of a step...is it top - bottom see attachment for reference. Does it process the blkmov...
2,077
the plant I am supporting uses a siemens graph function to do some of the step procedures. in several steps it waits for the step to execute for...
770
I'm still getting used to working with Siemens Step 7 Classic, and WinCC in the Simatic Manager package. I need a trend line on the MP377 HMI, and...
1,847
