S7 - Help with Counter using STL
Dec 2008
Toronto
42
I am just learning S7 and STL. So please forgive me if this sounds basic. I am using a CPU 416F-2 PLC.
I have a counter and it increments once everytime "M_10.1" is true. I set my Preset to that counter to 5 when "M_10.3" is true. Why does my counter continue to increase past 5? I am not really sure the purpose of the Preset! Thanks for your response.
A "M_10.1"
CU C 1
A "M_10.2"
CD C 1
A M 10.3
L C#5
S C 1
A M 10.4
R C 1
L C 1
T MW 12
Usually you set the counter and then count down, whilst above zero the instruction A Cx will set the RLO to 1, once it has reached zero it will set the RLO to 0.
If you want to limit it when incrementing, you would need a comparison instruction and disable when you reach your max.
hi,
Code:
//Count UP pulse
      AN    M     10.3
      A     M     10.1
      CU    C      1
//Count Down pulse
      A     M     10.2
      CD    C      1
//Compare value counter with threshold fix to 5 and stop Count UP
      L     C      1
      L     5
      >=I
      =     M     10.3
//Counter Reset
      A     M     10.4
      R     C      1
//Display counter value on MW12
      L     C      1
      T     MW    12
      NOP   0
I am just learning S7 and STL. So please forgive me if this sounds basic. I am using a CPU 416F-2 PLC. I have a counter and it increments once...
2,016
2,532
Hi everybody, I try to understand an S5 program exists in an old machine. In this machine we have 2 IP242A counter card used for reading...
7,450
I don't have much experience in programming. I can do simple configuration. it is like this. i want to add something to the existing ladder...
39
6,213
I have a program that has been functioning great and now would like to add an additional feature. Currently the program is based on timing, timing...
1,258
