S7 index bit
curlyandshemp
Jul 2005
Toronto
1,903
excuse the ignorance if this has been covered before, but I cannot find any past posts regarding the following code required in S7.
I need the equivalent of this Clgx rung to test an indexed bit into an input byte and output the result to the corresponding indexed bit in a Flag byte.
Hello,
not really sure what you need, but did you search form for "tidbits"?
Regards
Do you mean something like this ?
Code:
FUNCTION FC 6 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  bBit0 : BOOL ;
  bBit1 : BOOL ;
  bBit2 : BOOL ;
  bBit3 : BOOL ;
  bBit4 : BOOL ;
  bBit5 : BOOL ;
  bBit6 : BOOL ;
  bBit7 : BOOL ;
END_VAR
VAR_OUTPUT
  byByte : BYTE ;
END_VAR
BEGIN
NETWORK
TITLE =combine 8 bits into 1 byte
	  L	 P##byByte;
	  LAR1  ;
	  A	 #bBit0;
	  =	  [AR1,P#0.0];
	  A	 #bBit1;
	  =	  [AR1,P#0.1];
	  A	 #bBit2;
	  =	  [AR1,P#0.2];
	  A	 #bBit3;
	  =	  [AR1,P#0.3];
	  A	 #bBit4;
	  =	  [AR1,P#0.4];
	  A	 #bBit5;
	  =	  [AR1,P#0.5];
	  A	 #bBit6;
	  =	  [AR1,P#0.6];
	  A	 #bBit7;
	  =	  [AR1,P#0.7];
	  SET   ;
	  SAVE  ;
END_FUNCTION
Hi , I have a small problem with one of the integers that is storing a setting that is adjusted by an E700 HMI and stored in the programme. The...
3,081
I have watched for many years how people come up with ways of finding the bit numbers of bits that are set. RSLogix5000 has a FBC which works and...
10,701
hi everyone i need help with a bit shift application i am setting up on an assembly machine index table . i have a good understanding of the bsl...
4,079
Hi everybody. I got some problems about how to perform this task Now, I got an FB where I have this code snippet that looks like: L P##DBD_134...
1,144
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
756
