s7 iso-on-tcp netpro diag. connection closed?
udtwmc
Sep 2005
nottingham
48
I am unsuccesful in trying to establish an iso-on-tcp communication between a cp443-3 to cp343-1lean using the fc 5/6 (ag_send/rcv) blocks (I haven't done this before). The connection status in netpro says 'closed' in the cpu400 and 'passive waiting to establish connection' in the cpu300.
I have configured using netpro, across two separate projects, using 'other station' as the device to connect to. I am confident the ip addresses and subnet masks are correct for both projects.
I have made the cpu 400 the 'active' partner and have programmed only a fc6 ag_receive block (as I am after getting data from the cpu300). In the cpu300 project I have programmed the fc5 ag_send block.
Everything has compiled correctly and downloaded without errors to both cpu's.
What am I doing wrong?
Kind regards,
Thank you for your response.
I thought 'get' and 'put' uses the s7-communication-protocol which can't be configured using 'other station' in the project? I want to keep both projects separate.
I have used get and put before, but i was keen to try using the ag_send/recv blocks this time.
Regards,
For anyone interested...I have solved my problem, by paying attention!
I had not used the same TSAP addresses in both the local and remote plc's. So in cpu400 the address were set in netpro as TSAP-1 (local) and TSAP-1 (remote) but in the cpu300 I had TSAP-2 (local) and TSAP-2 (remote)
Regards,
Hello everybody, i uninstalled and reinstalled my Step 7 but afterwards any project I will open has an object that cannot be displayed or loaded...
1,362
Hi friends, This is my first work with simatic and I am having some difficulties to comunicate S7 with HMI. HMI: T5F-2 Beijer Electronics S7...
3,561
Hi Guys, I have the task of setting up communication between a S7-1214C with Version 3.0 Firmware, and a Beijer E1101 HMI. This needs to be done...
4,651
I had to exchange a cpu 416-2 DP-2XK04-0AB0 with a 416-2 DP-2XK02-0AB0. This cpu had multiple S7-connections and ISO-on-TCP connections. Because...
3,854
I have written my own dll (wrapping parts of libnodave) to communicate with a 1214 S7-1200 PLC via the builtin ethernet port. It is working fine...
4,435
