m6wiq
Hi Guys,
I have the task of setting up communication between a S7-1214C with Version 3.0 Firmware, and a Beijer E1101 HMI. This needs to be done over the ethernet connection.
However, I have had some problems trying to get the communication between the PLC and HMI to go ahead. E Designer does have the option for communication between a S7-1200 and this is established via an IP Address of the PLC, the Slot is selected and the link type is PG.
The error message that comes up on the HMI is "1:Comm error stn 0"
Network wise, the PLC and HMI is connected via a Switch but the S7-1200 has been configured to use a Router.
A lot of forums suggest the use of GET/PUT commands in order to communicate with this HMI but were unclear if this related to individual Data Blocks, the use of a GET/PUT function, or something else.
Many thanks,
William
Many thanks,
William
